It is currently Tue Jul 22, 2025 6:01 am
PostPosted: Fri Jun 01, 2007 11:37 pm
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
Many finger pickers and builders of like guitars have stated that, for finger-picking, they prefer cedar tops.
What kind and harvested from where please.
PostPosted: Fri Jun 01, 2007 11:51 pm
First name: Jim
Last Name: Kirby
Western Red Cedar
http://en.wikipedia.org/wiki/Thuja_plicata
You have to be very careful working with it - you can dent it from across the room just by looking at it funny.
Jim Kirby
kirby@udel.edu
PostPosted: Sat Jun 02, 2007 3:30 am
Among all the top woods I have used, this is the one that I find the most need to pick out in person, because they vary so much in stiffness. If they are given the hgiest grade on the usual visual criteria--sawn on quarter, little or no runout, straight grain, even growth ring spacing--they still can be very different.
You may not be able to buy in person, but if you can't, find a supplier who can pick out stiff tops for you, especially those that are stiff across the grain. For steel strings, in my opinion stiffer is better with cedar.
PostPosted: Sat Jun 02, 2007 5:40 am
Last Name: Abercrombie
Alaskan Yellow Cedar aka Alaskan Cypress aka Yellow Cedar is more like a hardwood in its properties. Lovely stuff (if you like the smell; some don't) and often used for back/sides for flamenco-style guitars- it's also good stuff for linings and such if you aren't too concerned about the weight.
Also, (not to start an argument) stiffness along the grain is probably as important/more important than cross-grain stiffness- something to keep in mind when you are massaging wood. Stiffness in the two directions doesn't seem to always 'go hand in hand' which can make choices even trickier.
PostPosted: Sat Jun 02, 2007 6:49 am
Fingerpickers are talking about Western Red Cedar harvested throughout the northern mountain areas of the North American continent.
PostPosted: Sat Jun 02, 2007 7:19 am
Last Name: Johnson
State: CO.
Thanks all
PostPosted: Sat Jun 02, 2007 2:15 pm
First name: Jim
Last Name: Kirby
I'll echo what Howard said. You can expect to see a lot of variation in cross-grain stiffness (regardless of long grain stiffness). I resawed one billet that was visually beautiful, as nice looking as anything you could want, and that was almost limp in the cross-grain direction. I don't know what to do with it.
Jim
Jim Kirby
kirby@udel.edu
PostPosted: Sat Jun 02, 2007 2:25 pm
[QUOTE=jtkirby] I resawed one billet that was visually beautiful, as nice looking as anything you could want, and that was almost limp in the cross-grain direction. I don't know what to do with it.
Drop it in the mail to me!
PostPosted: Sat Jun 02, 2007 3:06 pm
City: Battle Ground
Hi All....haven't posted here before, but have been lurking for a while.  I just strung up 2 cedar-topped guitars this weekend that are prototypes for a new design for me.  These were the first guitars I've built using WRC and I have to say I'm just tickled with the initial sound...very loud and present right off the bat.  I did trash one top while thicknessing, though...way too floppy across the grain, albeit very pretty!  I might have rejected it had I been able to get my hands on it prior to buying it....to reinforce Howard's thoughts.  I thickness by feel and the tops both ended up around .130" compared to about .110-.115" for the Sitka and Engelmann I've been used to.
Loren
PostPosted: Sun Jun 03, 2007 5:22 am
Anyone out there ever heard of Insence Cedar, also called White Cedar
(species Calocedrus decurrens) being used. It's another of the the Cedars
+/- common to the northwest. Just curious.
john
Users browsing this forum: Bing [Bot] and 19 guests
